My window seals and sunroof are all tight, and not leaking. I noticed my car smelled like the rainforest today, and upon checking under the carpet found the entire left side to be soggy. Coming from underneath? Common problem? Fix solutions? Thanks alot for the input, as I'm living in Vancouver, and rain driving is a must.
Water under my carpets. Help!
That's what I was thinking (the cracked floorboard plug.) I'm going to put it on a lift this weekend and check it out, but as far as a fix would go, what did you do?
That would indeed blow if it was gas...luckily it's only H2O.
Thanks for the help so far! Hopefully I'll get this thing nipped before it rains again.
It could be the drain tubes for the sunroof that goes down inside some of the pillars. These tend to get clogged up with tree crap and stuff and I have seen them back up water inside of interiors on cars before. I honestly doubt that cracked body plugs would soak the padding under your carpet that much. I mean I think it would be hard for water to flow upwards into your car to get under the carpet.
To see if the drains are clogged up you would need to do some interior removal and at least get to where you can access under the carpet . Prop a water hose on top of your car and try different areas of letting the water run for sometime and just keep checking the interior in the areas you have been seeing the carpet wet. If you see that by running water over it that it gets wet then you know that this is what is wrong and then you will have to access the rubber clear hoses to clean them out and flush them clear so that they can drain properly.
I would be willing to bet that it is coming from your wheel well.
here is a pic, seems to be a common place around here, I have welded up a ton of cars in this place.
just got to be careful not to burn down the car when welding this spot.
the yellowish color is where there is no more metal, that is the foam from the underside of the carpet.
Originally posted by mikeedler View PostI would be willing to bet that it is coming from your wheel well.
I would check for the floor plug first, then look for rust holes. If the sunroof drains were plugged, it wouldnt make the floor wet. it would make YOU wet. ;)Joe Funk -- Portland Oregon
That Guy.
03 X5. 3 liter obviously.
Thanks to all who are helping out!
What angle is that pic of the wheelwell looking at? Got under the car today, and can't seem to make that visual line up. Weather's been good so far, so it hasn't gotten any worse, but I've got to get this thing nipped asap, as this car is super clean, and I want to keep it that way. It's just on the rear passenger side (I accidentally said "left" in the original post). It doesn't seem to be drying out all that well either:(
It's times like these I envy Arizona car owners...
Thanks again, and I'll let you know when I figure it out.
Allright, so after going over the whole car (and being almost 100% sure it wasn't coming in the windows) I went outside and ran the hose on the roof and all over the rear pop-out windows. Lo and behold, water is getting in the passenger pop-out somehow, and running down beside the rear seat and into the rear passenger carpet. It was noticeable when water was literally dumped, but rain would have been less noticable and accumulated over the week. So, I found where it's coming from, but the fix is curious, as the seals and latch seem to be snug. Anyone run into this, where there just doesn't seem to be enough pressure between the window and seal?
It's been located (the main thing) and the weather stripping I put in there is definately temporary. Suggestions?
Thanks again!
