mine's pretty stinky on cold start, but runs OK. obviously different to drive, but not unacceptable.
surging while holding speed, more
here's some new stats... did a vacuum test and compression test tonight (finally got a T fitting i'd been looking for).
Before I continue, much of the drivability problems had vanished today, presumably after getting rid of much of the bad fuel. Nonetheless,
Compression came out much better than I had expected. Tested with 5 cranks per the Bentley manual, we saw 165 psi across the board, with no more than 1psi variance... except for cyl 3 higher by a 3-4 psi. Those numbers seem too good to be true, especially on a 223k engine, but we retested each cylinder 3 times, same results. Also, this was a dry test - no oil squirted in to test for bad rings.
The vacuum test was interesting. The bentley shows 15-22 inHg and steady at idle is normal- i found about 14" and lightly floating. Looks like a manifold or TB gasket is in order, since all other intake leak points are fixed (even the injector orings are recent)Last edited by fretburnr; 08-02-2007, 11:28 PM.Jay
how did you do the vaccum test, did you put a vac pump on where the fpr connects or what??Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
Originally posted by TimKninjaIm more afraid of this thread turning into one of those classic R3v moments, where Pizza gets delivered.
