Washer Pump
    Washer Pump
    So I just replaced my window washer pump. Not a big deal at all except now washer fluid leaks out from the hole where the pump drops into the tank. I'm not really familiar with how it sat in there before, but am I missing some kind of o-ring or something? It just seems not make a good seal. Any thoughts?
    1985 325e - 5000 RPM's of Fury
    put some caulking around it if you cant figure it out, that will stop the leaks.
      did you push the pump all the way down into the o ring?
        I wasn't aware that there was an o-ring. I didn't see one come off my old one, and I don't think it came with the new one. I guess maybe I could have lost the o-ring with taking the old one off, but I doubt it. I'd rather not caulk it if I didn't have to but that may be a last resort. Any other ideas?
          the o-ring is part# 61661365657... less than $2 at pelican or the dealer... i tried using sealant tape but only the o-ring did the trick
          Jay
            I guess I dropped the o-ring somewhere. I'll get one so that my washer fluid warning light will finally be able to turn off.
