My car is running a little stumbly, and after concluding there were no vaccuum leaks I began to look at the ignition system. My cap to plug wires read resistances around 5800 ohms, except for #1 that was 6200 ohms. The repair manual says they should be between 4500 and 5500.
Do they need to be replaced? I wouldn't think so. Cap and rotor are both new. As long as they are firing then all should be ok, right?
Also, would a bad fuel pressure regulator cause a loss in HP and stumbly idle? How would I check that?
