Cleaning washer nozzels and lines?
  • NOMAD
    • Feb 2007
    • 1502
    I like a clean windshield and the washer nozzles don't spray too well on my 91. I think the PO used washer fluid all the time and it has left deposits of crud over the years. I think there is a regulator or splitter of sorts that is up on the hood and I'm thinking it is blocked.
    Any tips on cleaning these out? Should I take them out and soak them in degreaser? I looked on ebay and couldn't find any and it seems pointless to buy used.
    '74 2002 - Build blog at
    nomads2002.blogspot.com
  • atomic
    • Jun 2007
    • 5691
    you can try a short brissled brush to clean the nozzles out then I would try just soaking any of the parts you think need it in just soapy water. Degreaser if any left in the system could hurt the paint finish and/or cause your windshield to get a film on it that might cause streaking
    • 86espowa
      • Jun 2007
      • 296
      disconnect the tube that is near the washer fluid tank and spray compressed air into the line. that will clear any and all shit in the lines and sprayers.
      • AndrewBird
        The Mad Scientist
        • 11898
        Get all new tubes and nozzles? They are still available AFAIK.
        If you don't want o buy new, do what 86espowa said and use compressed air. I would blow it backwards though, starting at the nozzles. Don't want to blow crud through the nozzles and clog them even worse.
        • 87-325ic
          • Apr 2006
          • 1198
          use a small needle to clear it up and aim it..
          like ive been needing to do..
          • AlarmedBread
            • Sep 2006
            • 1510
            theres a check valve near the front of the hood that you'll have to disconnect to be able to blow them out backwards without risk of popping a line. I use one of the needles for filling up footballs etc.
            • NOMAD
              • Feb 2007
              • 1502
              Good idea, I'll have to get on that. The needle ting for aiming never seems to work right for me. Maybe I'm just no good at it. I always end up aiming it wrong 1000 times.
