I had a problem with my signal lights, they won't work... I suffered an small "short circuit" when trying to make the bumper lights act as signal lights and blown the hazard fuse, I replaced the hazard fuse, but I still don't have signal lights. What should I do?
Signal lights won't work
Tags: None
I did this same mod on the 87 325 - I had zero problems, has been working fine since day one.
I'd say, get everything back to the way it was originally, and see if it works that way. Then start the mod from scratch again. May seem like twice the work, but to make sure everything works right still, it's always best to revert back to the way it was before.
- Did you get the walkthru off bmwe30.net? Cause that's the one I followed. make sure you did everything as it said - I did it, it worked perfect. Also be sure to cover those wires up with electrical tape - make sure everything's covered. ;)- Sean HayesComment
yeah, undo it and did it again, and only my hazzard lights work... the signal lights wont :(1994 BMW 325 i/Canon Rebel XT/28-135mm IS f:3.5-5.6/Canon 50mm f:1.8
do you happen to know what fuses are those?1994 BMW 325 i/Canon Rebel XT/28-135mm IS f:3.5-5.6/Canon 50mm f:1.8
I've replaced the fuses and nothing yet1994 BMW 325 i/Canon Rebel XT/28-135mm IS f:3.5-5.6/Canon 50mm f:1.8
look... I know have the car without the mods... and then again only the hazzards work, but the signal lights dont.... have I broke anything? :(1994 BMW 325 i/Canon Rebel XT/28-135mm IS f:3.5-5.6/Canon 50mm f:1.8
matbe your hazzard switch
I have that problem and i was told to change my hazzard switch try it if it works ill do mineComment
