After noticing that I had chewed up a set of front tires after 10000 miles I got an alignment, thinking I had hit a pothole or something to mess up the toe. I am running H&R sports with bilsteins and m3 CABs.
Here is my sheet
Front Left:
Camber: -1.6
Caster: 9.3
Front Right:
Camber: -1.5
Caster: 8.5
The toe was out somewhat but the before numbers don't matter because they had to straighten my steering wheel, which was put on crooked. The specified caster range for the e30 is 8.0-9.0. Between my front tires there is a .8 degree difference. My car also pulls to right a small amount with correct tire pressure.
Does this difference in caster account for my front tires getting owned?
Here is my sheet
Front Left:
Camber: -1.6
Caster: 9.3
Front Right:
Camber: -1.5
Caster: 8.5
