Car won't start strange symptoms
  • Court M3
    • Jan 2004
    • 6713
    Posting for a friend here
    Car 85 E30 320i
    Symptoms needs to be jumpstarted, then has a rough idle until it's put in gear or try to give it gas and then it cuts off and has to be jumpstarted again
    It was taken to a mechanic before that bypassed something with a dash mounted starter. Thinking it was the ignition control unit.
    Same mechanic also put in wrong air filter and spark plug wires and used duct tape to repair a cracked intake bellows.
    Thinking a tune up would be in order, but can't figure out the remote starter switch thing Any idea why it won't start after it's put in gear or when you try to give it gas
    Any help appreciated, since it looks like that will be my weekday project for awhile
    Continuous For Sale Thread
    323i s50
  • James Crivellone
    Head Janitor
    • 6305
    dead battery and a bad alternator?
    • Court M3
      • Jan 2004
      • 6713
      Brand new battery, around 6 months old. The Alternator on the other hand is probably still the OEM unit it came with.
      Is there a way to check the alternator?
      323i s50
      • Sean
        • 5793
        Remove it, and take it to a place that could test the voltage it puts out (I'd say Schucks, Napa, etc...but you're not in the US). I'm not sure what places test alternators there.
        - Sean Hayes
        • Court M3
          • Jan 2004
          • 6713
          Aren't you parting out a car? :D Might need yours if you still have it
          323i s50
          • clavinZERO
            Hella sick E30
            • Mar 2004
            • 2027
            fuel pump and fuses and relays all ok? mine just took a shit 2 cities away from where i live and i had to pop in a new pump in front of someones house. if it turns cranks and cranks it not the battery. check the AFM cable also, although it shud start without it, just rich as hell.
            "BMW Style 32 Poster-Child"
            HTTP://WWW.CLAVINZERO.COM/e30-5-lug
            **(My Guide to E36 M3/Z3 1.9L 5-lug Swap)
            • Wes325
              • 563
              That definately sounds like a fuel pump. I just replaced mine yesterday. Easy to do. You dont even have to drop the tank, just take out the back seat and carpeting and its right there.
              ________
              girlfriends pics
              - 318is 4 life
              • clavinZERO
                Hella sick E30
                • Mar 2004
                • 2027
                discon battery (-)
                4 philips on the cover panel
                remove 6" fuel hose between hard line and pump (PUT NEW ONE ON WHILE YOU ARE IN THERE)
                4 8mm nuts on the level sender- pull it out, let it drop off a bit
                twist fuel pump counterclockwise, remove, let drip
                clean pump mounting surface on top of tank.
                reverse.
                • Court M3
                  • Jan 2004
                  • 6713
                  Will only turn or crank if it's jumpstarted. After that, as soon as you put it in gear it dies and has to be jumpstarted again. :(
                  323i s50
                  • Sean
                    • 5793
                    Yeah, I am. School has been a major pain in the ass though, so I haven't gotten anything off the car. Hopefully this weekend, I'll start takin some small things off.
                    I was considering keeping the alternator, since it'd be nice to have down the road whenever mine goes out - ya know. :) I'd suggest looking at all the other possibilites though, and definately have the current alternator checked, so you know for sure if its that or not.
                    Definately try checking the fuel lines / pump and whatnot.
                    - Sean Hayes
                    • Court M3
                      • Jan 2004
                      • 6713
                      Any other ideas? Haven't been able to work on the car since the inlaws are visiting from Japan
                      323i s50
