diff. removal
  • viali8
    • Nov 2005
    • 673
    diff. removal
    I have removed about three diffs. by now from various e30s. I have no problem removing the half shafts and the two 19mm towards the front of the diff. But those two 19mm bolts on top of the diff are a major PITA. What tool works best to remove those buggers. thanks
  • 86espowa
    • Jun 2007
    • 296
    i undo the bushing holding the diff up, and just lay under there (the two bolts on the top are the last thin i take off) and i put a jack under the diff, then just strain and reach up and undo them.
    • Garageaholic
      Freestyle Fabricator
      • Dec 2005
      • 5204
      yeah, it simply hangs down from the subframe bushings. You must take a 19mm boxhead wrench and get it 1/8 turn by 1/8 turn. It sux, but it's how it's done...
      I think the other 2 you can fit a 19mm socket in there...
      Recent Rebranding!!
      E30 SM62/S62
      E30 M60 V8
      E30 M30 Big 6!
      Instagram.com/garageaholic
      Youtube.com/garageaholic
      • Mike325
        • Mar 2006
        • 3685
        Just make sure that you have your hand on the wrench while it is on the bolt head. It will most likely slip off while you try to turn. I am sure you know this already though. Yes it is a major PIA but it helps if you are strong.
        Originally posted by Kershaw
        • golde30
          • 11464
          this is why i bought a set of wratcheting swivel head wrenches...
          IG: @Baye30
          • Rigmaster
            • 3464
            I usually use 2 19mm wrenches- put the box end on one of the top bolts, and then put the box end of the 2nd wrench in the jaws of the open ended side to get some extra leverage. You only need to do this to crack the bolts loose, then you can switch to a 19mm gearwrench if you have one- that's the easiest way I've found to do it- and it has not failed me yet. I've probably pulled 100 E30 diffs- no BS.
            Bret.
            • rcko
              • Mar 2007
              • 295
              Bret.
              2nd Bret....
              - 0.05s and 0.1s FTW!!!
              • viali8
                • Nov 2005
                • 673
                thanks guys this helps. looks like i need to buy some new tools!
