ETA guys look here
  • Avus_325is
    • Mar 2004
    • 446
    ETA guys look here
    We are in the final stage of rebuilding my friend's little project eta and I've run into a slight snag. There is one wire we cannot find the connection to. It's a blue, two prong/plug female connector which we cannot find the male end to. The wire comes out of the wiring harness right beside the cylinder head and is zip tied to the firewall with almost no slack. The lack of possible places for a plug to be in the vacinity is what really pisses me off.
    Could somebody please check under their hood and see where the wire that this plugs into is running? It could be that I just got home from working on it at 2:30am, and am just blinded by tiredness. Any help or hint would be greatly appreciated.
  • Super Eta
    • 1884
    I have replaced my engine in my project eta and im sure i know what your talking about but man im blinded by tiredness aswell and my brain shut down about an hour ago. :?
    If i can find out tommorow i will let you know but i cant think right now.
    • Ryan Stewart
      I Love Miatas
      • 8978
      Yes can you photograph it? I have a LOT of things that arent plugged in on my car, maybe its one of those things that just hangs because of a common wiring harness.
      The only blue thing i can remember is the ICV connection.
      Im now E30less.
      • James Crivellone
        Head Janitor
        • 6305
        Cold start valve, right above the center of the valve cover
        the ICV connection is black
        • Avus_325is
          • Mar 2004
          • 446
          The plug looks identical to the plug that goes into the ICV. I'm thinking that on monday when he gets back we're going to go ahead and get the cooling system hooked up and try to turn it over.
          Can't get any pics until then. Guess I should have thought of that last night.
          • 86325e
            • 228
            Is it the wire coming out of the engine wire harness or the body wire harness?
            Eric
            85 325e M50 and auto to manual transmission conversion...
            • Avus_325is
              • Mar 2004
              • 446
              I beleive it is just running to the fuse box.
