Whats wrong with my 318?
  • LedZep244
    • May 2007
    • 10
    My car won't start and I dont know why. I changed the blower motor, and in the process disconnected the wires on the left side of the firewall in front of where the ecu lives. Im talking about the nut you take off.
    At some point I forgot to disconnect the battery and one of the wires touched metal and sparked. After finishing I put everything back together, but the car just spins over, and sounds funny. Doesnt even think about firing at all. What did I fry? I tried to pull codes and the check engine light does not come on anymore.
    Anyone know whats wrong with it? Ran perfect before.
  • HST
    • Jan 2006
    • 757
    My first guess would be coil pack if you are not getting spark. It could be the ECU, but I'm not sure how to test that. I'm sure some here could tell you.
    Originally posted by KingB
    Scratch my back and I buy a prostitute for you, to rub your balls. HAHA now thats some funny shit.
    • jrobie79
      • Mar 2006
      • 2526
      crank posistion sensor, same thing happened on my 91 318
      1991 318i ---- 308K - retired
      • frost_dxb
        • 40
        Test:
        Coil pack - remove a spark plug wire then let some one crank it should spark
        ECU - remove one of the injectors then let some one crank it should spay fuel
        2002 C200 KOMPRESSOR
        1995 318i - M42B21 on the making
        1986 325e - Just another Project
        1989 M6 - SOLD in DXB
