Do you have new shifter bushings?
  • friday
    • Aug 2007
    • 7
    I don't know how tight a new shifter is. My shifter moves about one and a half inches when in gear with the clutch engaged. How good is it when you have new bushings in the shift arms. In my pickup (also with 100,000 miles and a lot longer shifter) it moves about 1/2".
    I'm trying to decide if it's worth doing the bushing job.
  • DoriftuEvo
    • 236
    This is our comprehensive shifter thread. It should have more than you ever wanted to know.
    Personally, I was not impressed with the tightness of my shifter with all new stock bushings. Some can be replaced with brass or delrin bushings for a better feel. You should have a good idea of what you want to do after looking through the above thread.
    • StereoInstaller1
      GAS
      • 22679
      Me too on the whole "Not Impressed" thing.
      Don't even want to think about removing the transmission to fix it until the swap.
      Closing SOON!
      Thanks for 10 years of fun!
      • Jparkr
        HR Admin
        • Jan 2006
        • 3494
        I LOVE my shift bushings, James criv and i machined our own. his mtech has brass and my 90 325is has aluminum... you wanna talk about no play :-)
        1987 PRO-3 car /1990 325is (2.7i Concours)
        • erik325i
          • Jan 2005
          • 3567
          I highly recommend getting the UUC Delrin shift carrier bushing. I have it in my car and it greatly reduces slop.
          -Erik
          • 86espowa
            • Jun 2007
            • 296
            I can talk about no play also. solid aluminum bushings make for one helluva shifter. i love it.
            • fretburnr
              • Jan 2005
              • 1496
              I've been meaning to do this for too long. I have the UUC delrin carrier bushings sitting in a box with new selector rod joint, washers, foam plug, rear mount, bitch clip, the list goes on.
              Jay
              • blazing
                • 274
                I just finished mine up with a modified selector rod joint(bearings counter sunk into it),a UUC evo2 with bearings on the lower ,a new selector rod derlin carrier etc...
                It is a night and day difference from what it was but on mine there will allways be a little side play in the selector shaft of the tranny itself.
                My linkage is as tight as a nuns asshole and the shifter still moves roughly 1/2" side to side in gear.
                But again night and day from sloppy 166,000 mile factory stuff.
                • Jparkr
                  HR Admin
                  • Jan 2006
                  • 3494
                  Aluminum bushings FTW!!!!!!!!!!
                  • BrandC
                    • Jul 2006
                    • 444
                    Any machinists out there willing to make a few brass/aluminum shifter bushings for us track rats?
                    -Brandon
                    • redhatpat
                      • Aug 2005
                      • 656
                      Originally posted by blazing
                      My linkage is as tight as a nuns asshole...
                      Ummm....
                      • Zya8187
                        • May 2007
                        • 195
                        I don't have solid bushing in my e30 but when I put solid bronze bushing in my 300zx it was a HUGE different.
                        • Jean
                          • 18228
                          e30 shifters = teh suck, especially sheet metal console type...
                          • AlarmedBread
                            • Sep 2006
                            • 1510
                            All you need is a drill and some bits.
                            Go to your local hardware store (ace, true value etc.) Get some brass bushings/bearings.
                            1/2"OD 3/8"ID
                            You may have to slightly drill them out/sand the outside depending on how worn your parts are, make sure to test fit a lot and go in small steps untill you get them fitting perfectly a micrometer is helpful here. they are soft enough that they will expand if you force them over the rod, so be careful. It takes a little time and patience, but it worked well for me and only cost $8 or so for everything.
                            I have about 1/16" front to back, and 1/4" side to side play in neutral, this could probably be reduced with a new selector rod, but I didn't think to order one.
