I finally got the megasquirt up and running on my 88 turbo m20.. and going through the normal tuning process I have this hesitation at exactly 3600 RPM and 9psi every time I go through an acceleration run.. I have tried every mixture possible to no avail. it allways looses about 50 HP at that point for a second or so and then continues on its normal way at full power.
Is there something else that is happening at this RPM that I am not accounting for? before the MS it did it occasionally, even naturally aspirated but only ever happend when it was raining(I think).
Once I did the tuirbo and engine rebuild and tuning with a MAF, it went away. It is now back with the MS install. every other pressure and load at that rpm it doesn't hesitate but at that node on my Volumetric efficiency map it appears..
Could this be a timing issue? it is not detonating.. and I know that TCD is running systems on stock timing.
Any help would... matt are you having these porbs?
