How hard to take the steering wheel out!
  • Makster
    • Aug 2007
    • 276
    I have 89 325i no airbag, what is the steps to take the oem steering wheel out!
  • Mike325
    • Mar 2006
    • 3685
    Take off the roundel in the center with a small flat head screw driver. Then there is a 21, or 22MM nut in there. Have a friend hold the wheel while you loosen it. Do not use the cylinder lock tab, the tab that locks the wheel when you take the key out, to hold the wheel.
    When the nut is off, put key in ignition and turn to release lock tabe and pull off. One min job.
    Good luck.
    Originally posted by Kershaw
    • smonkbmw
      Professor
      • Jun 2006
      • 4549
      22mm
      • ACHTUNG
        • May 2005
        • 2397
        Originally posted by Mike325
        One min job.
        Seriously
        1989 US E30 Cammed S52
        Under Construction: 1983 Euro E28 Cammed LQ9/LS3 Heads/Jakeb E28 LSx Kit
        • vivalegreg
          • Apr 2006
          • 1313
          +1 word...i love no air bag steering wheels...any time your alingment gets out you can just "adjust" via change the steering wheel position hehe
          e30s r kool
            • 37832
            I use this every time with no issue.
            Classic BMW Specialists
            Grover Beach, CA
            www.BimmerHeads.com
            • thereisnoyun
              • Feb 2007
              • 2301
              next thread from him probably be, "how do I remove the lug nuts on my wheel, I have standard four lug bottlecaps."
              • fretburnr
                • Jan 2005
                • 1496
                same here.
                Jay
                • Mike325
                  • Mar 2006
                  • 3685
                  I thought it was bad to use the tab. No?
                  • friday
                    • Aug 2007
                    • 7
                    I have the three spoke wheel. I pried off the roundel and had to glue it back on. On my wheel the horn button pries off.
                    • PeaveyBassist
                      • Sep 2004
                      • 3511
                      Originally posted by fretburnr
                      same here.
                      Also here.
                      Will
                      RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
                      Welcome e30 (brilliantrot '90 325is) 12/23/06
                      DaveCN = Old Man
                      My signature picture was taken by ME! Not by anyone else!
                      If people keep quoting me in their sig, I'm going to burn this motherfucker down.
                      • 86espowa
                        • Jun 2007
                        • 296
                        Yeah, until your tires are chewed apart by improper alignment
                        • Jscotty
                          • Jan 2007
                          • 2285
                          I always use the tab to hold the wheel. I use my 4-way lug wrench to loosen the nut so that i can get the leverage I need.
                          The few times I had the car towed with the front wheels on the ground, the tab was strong enough to keep the wheels from turning so I cannot imagine that unbolting the steering wheel would put that much more stress on the tab. In fact the first time I attempted to remove the wheel, I didn't realize that I had to turn the key. So I spent 30 minutes fighting and wrestling with the wheel to get it off. I even hit it with the sledge hammer a few times. By the time I realized my mistake, there was already metal shavings on the carpet from the inside of the steering wheel.
                          • Vlad_318iS
                            • Feb 2007
                            • 151
                            I am wondering if it is possible to take the steering wheel off without the key. OR what is the best way to break the lock cylinder if there is no other way?
                            thanks.
                            hahahaa, that made me laugh hella hard.
                            http://vnmi.mybrute.com
                            :razz: 1991 Alpineweis 318iS
                            :arrow: 1991 Briliantrot 318i
                            • blueapplesoda
                              • Dec 2005
                              • 1904
                              yes i am wondering too...i remember finding a junk car with no keys and i wanted the mtech1 3 spoker off of it....but i couldn't get it off after trying for like 15 minutes to break the lock tab so i just left it.
