Adjustable Voltage Regulator; better idle and brigther headlights
  • rcko
    • Mar 2007
    • 295
    Found about this little gem while reading this month local BMWCCA newsletter: http://davebarton.com/AdjustableVoltage.html
    I bought the Internal Adjustable Voltage Regulator. Installation took all of 15minutes and has made a difference. Brighter running lights and improved more consistant idle. Interesting how these little things make a difference. Regulated voltage is now 14.1 volts at 1.5k rpm no load and 13.9 with high beams, ac, stereo on. I can dial it up to 14.5 volts if need be.
    The stock regulator was down to 7mm on one brush and below 5 on the other so it needed replacement.
    - 0.05s and 0.1s FTW!!!
  • nefarious7907
    • Jan 2005
    • 1170
    With a new stock voltage reg, I get a hair over 14 at idle if I blip the throttle once. I have voltmeter and my voltage doesnt doesnt move around too much.
    I am kind of skeptical about the adjustablity and if that would be a good thing for your whole electrical system. An electrical fire is probably the damaging thing that can happen to your car short of totalling it.
    http://www.cardomain.com/ride/657387
    • rcko
      • Mar 2007
      • 295
      It is a same price alternative to the stock regulator and capable of adjustability within specs of the system. 14.1volts at 1500 rpm is within spec. Most of the original older alternators have a hard time pushing past 13.5 volts so this reg provides the ability to get to 14.1.
      The extra 0.5 volts allows you to get that extra bit of performance. The extra voltage (within spec) helps the ignition coil re-charge faster thus providing better spark at higher rpms.
      As with any mod, if you dont know what you are doing or do not have the correct tools you can damage the system. For those having a hard time getting voltage to read above 13 volts with new batteries and regulators this might be a good alternative. Just make sure you adjust the thing is dialed in properly...
      • george graves
        • 19993
        Very interesting...I might get one. But that web design - Uggggg...
        Originally posted by Matt-B
        • NC325iC
          • Mar 2004
          • 6565
          true that bout barfed when i clicked the link
          • kickarse
            • Aug 2007
            • 6
            Talk about an involuntary heaving action for that site...
