My mom's 85 528e has had an idle problem almost ever since we got it. Right now it has about 240k and the motor is all stock. My dad bypassed the ICV because no matter what he did when the car was in park it would idle around 1500. Put it in gear and it goes down to around 800rpm. We used to get by okay by just turning it off in gear. (it would idle normally when cold) So now with the ac on, and the car in gear it will not run without turning the idle up on the throttle linkage, which in turn causes the idle to be about 2 grand when in park. We seem to think it has a major vacuum leak based on the fact that when the oil cap is off or the dipstick tube is out it will not die.
When we hooked the vacuum gage up to it, it read 22 inches. Does anyone know if this is normal or not? Seems to like 22 is more than normal, and doesnt constitute a leak.
My dad is going to get a new ICV as well as all new rubber hoses and probably valve cover gasket as well. Any ideas or suggestions. *Turning the screw in on the ICV all the way in still wont get the idle down low enough when in park*
