Cutting access holes in trunk for diff bolts?
  • a32guy
    • Mar 2005
    • 183
    Anyone ever do this? I picked up an e30 and the diff bolts are backed out 1/2" and siezed in there. I used heat and deep creep for a while, but its just not worth the effort. I'd like to know if its possible to get to the bolts through an access hole? This way I can just throw the impact on em.
    Thanks in advance.
    -Chris
  • StereoInstaller1
    GAS
    • 22679
    Hell of an idea! Do it. Make your holes an appropriate size so you can buy caps to seal your trunk back up should you get luck enough to have flat metal above them...I am gonna look at mine today!
    Luke
    Closing SOON!
    Thanks for 10 years of fun!
    • dark89e30
      • 263
      I would try some Mopar rust penetrant. Its the best thing they make, and if it works, you don't have bolts broken inside your diff case...
      • JonathanJ.
        • Aug 2007
        • 145
        Don't know if there is room for this, but a chisel and hammer often work for me to knock rusted bolts/nuts loose. Obvious downside is that it will destroy the bolt/nut.
        Good alternative to an impact.
        • browntown
          • Jun 2004
          • 3524
          I really like that idea, because I hate removing rusty diffs on these cars. I will say that the best tool I bought for the job is a flexhead 19mm gear wrench -- then slip a pipe over the wrench or hook on another box wrench and you got some leverage
          • jmarch
            • Oct 2004
            • 163
            It's not that hard just to drop the rear crossmember with the diff intact.
            1995 Porsche 993 6 speed
            2001 BMW M3 6 speed - DD
            2001 BMW 530iA Sport - Hers
            2005 KTM 450EXC 6 speed
            Gone:
            1988 BMW M3 2.5 EVOIII Clone
            1988 BMW 325is x2
            1985 BMW M635CSI 286hp
            2001 KTM 400MXC
            • Erick
              Official R3V Drifter
              • 11169
              Word. And dont forget the 10mm Hex wrench for the half shafts + the 13mm for the drive shaft.
              ..::Support FullOpp::..
              FullOpp Stickers for sale!
              Feedback Thread
                • 37832
                Exactly what I was about to say.
                Classic BMW Specialists
                Grover Beach, CA
                www.BimmerHeads.com
