i have done the first two cycles of torques on the head. The bentley says to run the engine for xx minutes before doing the final torqing. Is this necessary/will at affect the valve cover gasket at all. i have two so its not a big deal either way. Also race wear studs are in, i had trouble getting them all down an even amount because they didn't have anything (like a hex) to turn them with. We double nutted them down to where they should be, but some are uneven....is this a problem, should i work with them more before running the engine?
tightening the head
with the newer Torx style head bolts you don't need to wait or heat cycle them. Just torque once, then 90 degrees and 90 degrees again. -
When installing new studs, it helps to run a bottoming tap through the threads and use compressed air to clean all the junk out. If the threads appear 'dry', you may want to add a drop or two of oil to the tap. The goal is not to 'cut' but to clean/chase debris from the threads. It may take a lot of air and a couple of passes with the tap. New head studs should install about 1/4 the way down by hand and easily double nutted to the bottom. Also, it helps to measure the depth of EACH hole and transfer that depth with a sharpie to the stud for that hole. It will help you know when you are getting close to bottom. I have even used long Q-tips from my gun cleaning kit to assist in debris removal from the bottom.Don't forget the good things Hitler did.Comment
If you dont have air the q-tips are good,
I just put in stefans head th other day and then noticed when adjusting the cam timing that it was completely 180° off so I can´t turn the head unless I remove the head and kinda time it right and then re install for minor adjustments,,
note : this removal and install is not regular practice as we are only doing this to check if the number 6 is running cold ( i.e coolant coming from the valve area into the port) so to see if it´s just like the oher head we pulled to determine the block faulty or the head, block preferably as we have a few :) and that would make 2 heads ok and one block, wich would be perfect for next winters projects
besides stefan already bought another complete engine and is going to use that with a new gasket and torx,,
sorry to go off topic but somehow I just had to express my self :)Gunni
@ Prodrive / Aston Martin RacingComment
