intake manifold death tube question about o-ring
  • DrMcDave
    • 1793
    is there an o-ring at the top where it connects to the intake manifold, i have the one on the bottom. I forget if i saw one at the top when i took it apart.
  • modifiede30
    • 1208
    Both ends have one, at least they did in mine.
    Driving is the only way to go faster....
    • M-technik-3
      • 18946
      Both ends.
      • chesster6969
        • 321
        WOuld not having an O-RIng on Both ends cause an unstable idle or major vacuum leak?
        Anyone have the part numbers or if they are available from the dealer?
        • modifiede30
          • 1208
          I'm sure the dealer would have them but you could probably find them at a hardware store. Just take the pipe with you and see if they have any o-rings that will fit. I'd also check with local auto parts stores. If you can't find one, let me know, I may have one sitting around from the recent rebuild I completed.
          • Avus_325is
            • Mar 2004
            • 446
            We forgot to put them back in place when we put the head back on my buddy's eta. Been driving it for a week with no problems with the idle or any sign of a vacuum leak.
            • DaN
              • 1265
              I believe its possible for it to not have a rough idle, but how does it not leak oil???? You must have the o-ring in there, and forgot. Or it was stuck in the intake and you didn't notice.
              I have both o-rings in mine and that bitch leaks. :twisted:
              • skat 325is
                • 296
                It'll leak like a mofo, the tube has 2 o-rings and a washer that goes on top of the bottom o-ring to hold the spring....i noticed mine didnt have the washer, i replaced everything down there.
