rear fuel filter removed looked at, now what!
  • kencopperwheat
    King of Kegstands
    • 14396
    ECU?
    Coils?
    Originally posted by Gruelius
    • cnardinola318is
      • May 2007
      • 30
      thanks I'll check the plugs, and hose, the filter is new
      all it did is run out of gas,, wtf, lots fails when that happends,
      91 318is New Orleans Lives
      www.nolatonight.com
        It isn't unkown for a fuel pump on an older BMW to not work correctly after the car is run to empty. That can be as a result of overheating the pump or it can be the result of sediment being stirred up and sucked into the pump. Since the sediment is usually mostly rust and fairly abrasive it can take out a pump that's on its last legs. You really need to run the fuel pressure and delivery tests.
