Hypothetical Inspection Question
  • spoolin318i
    • Dec 2005
    • 96
    Is it possible to temporarily dissable the check engine light and anti-lock brake light without damaging it for further use? A imaginary car needs to pass but would still like to retain these two systems for the future.
  • backtrail69
    • Jul 2005
    • 4471
    um... switch...
    :: PNW Crew ::
    '87 325 4dr, '74 2002
    • spoolin318i
      • Dec 2005
      • 96
      Originally posted by backtrail69
      um... switch...
      switch what?
      I have heard of the ABS relay being removed (does this turn out the light?) but do not know exactly where it is located (somewhere under the dash on the driver side).
      As for the check engine light, what should I do?
      • spoolin318i
        • Dec 2005
        • 96
        NVM,
        someone pointed me to this
        thanks for the help!
        • SpecM
          • Oct 2005
          • 4531
          -I don't know how it is in Texas, but in NC the CEL bulb must work to pass inspection. Called a Key ON, Engine OFF Bulb Test. And does your ABS have to work too? Not in NC.
          -Not questioning you or anything, I'm just curious about it.
          1989 cirrisblau-metallic 325i
            I can't imagine the inspection techs requiring those lights to be off and not checking to see if they come on for the bulb test and go off once the engine has started. To get around that (hypothetically) you'd need to simulate the bulb test.
