My 1989 325is has been leaking heavily for a couple weeks now. I've been using Mobil 1 15w-50 in it for about 3-4 years now with NO leaks or irregular consumption at all, until late September, only a couple days before I went away on vacation for a couple weeks. On inspection, the leak is where where the two oil cooler lines join the oil filter housing. Here's a diagram:
http://www.realoem.com/bmw/showparts...17&fg=05&hl=12
If I haven't been clear, it's leaking from where the #4 is. I want to just replace the seal/o-ring, but I'm wondering why BOTH lines will be leaking at the same time. What are the chances that both seals broke at the same time, or both lines came loose simultaneously?
This is a heavy leak. When the car is off, it leaks minimally. When the engine is running (driving or idling), it leaks about 2 drops/second-- way too much to drive around in, IMO. I just came back from vacation yesterday night, and I want to fix this. I don't need to do it NOW, as I have another car to drive, but I want to take care of it soon. Thanks
