clutch master cylinder
    i believe my clutch master has just shat itself, but there doesnt appear to be any fluid leaks.
    when i press the clutch in it goes straight to the ground and i can pull it up and it will go well past where it should (it even knocked the sensor off)
    can anyone confirm that this is indeed only a master cylinder problem, the slave is practically brand new
    Master for sure.
    Originally posted by Kershaw
      score, ill order one tomorrow first thing and ill do it this weekend when i do my brakes
      anyone have a good writeup on changing it out, if i could do it in the parking lot where it is thatd be great if not ill have to AAA it home
        This will not be easy. The hard line that connects to the master is located under the booster. There are two 10 mm bolts holding the master to the bracket under the dash. Then one holding the pushrod to the clutch pedal.
          looks like AAA it is...
            Crap I have just ran into the same issue. I dont have time to work on it and I actually not too technical when it comes to this, but does anyone know what the cost will be around just for parts and how much labor it would take?
              parts are about 40+shipping if you order online, got mine from bavauto
              hasnt come in yet so no word on the labor
