fuel gauge always registers as full
  • inwoo
    • Aug 2007
    • 74
    I have a slight problem. Ever since i purchased the car, the fuel gauge always reads FULL. However, the fuel low light works, so my best guess is that the fuel tank sender is still operational.
    Symptoms:
    * Fuel gauge is always full
    * Fuel low light WORKS
    * Temp Gauge WORKS
    Probable Causes:
    * Ground Nut is loose (checked)
    However, i checked that the ground nut is not loose, and opened up the cluster to clean up the ground contact of the fuel and temp gauges
    * Sender is bad? (not checked)
    * Wires between the sender and cluster is bad? (not checked)
    Question:
    * if my low fuel light works, does that mean my ground on my cluster is working?
    * also, if my low fuel light works, does it mean the sender works to some degree?
    * could i just have a bad fuel gauge? if it always reads full? (when the engine is off , it reads empty )
    * what is the resistance in ohms when the gas is full , vs when the gas is empty?
    * does the sender has 2 independent systems for activating the empty light as opposed to the gauge?
    hypothesis:
    * if my grounding was wrong to my cluster, i would read empty on my fuel gauge?
    * thus, since the resistance of the fuel gauge, since it reads full , would be near 0-5 ohms
    * therefore, there is probably a short somewhere, such that, it always reads very little resistance.
    * my fuel low light works, because it is a different pin, which is not shorted.
    * also, due to the fact that my low light works, the sender ballast works properly?
    My guess would be a shorted sensor or sensor wiring. With the float at the top (full tank) the sender has 0 ohms and with the float at the bottom it will read 56 or 74 ohms, depending on year of production.
    • Tarn
      • Sep 2006
      • 212
      I had the same problem. I replaced the sender and its fully operational now.
      • mattdk318i
        • Jun 2006
        • 3953
        The sender is stuck, AKA bad. Go ahead and replace it and im sure your problem will be solved
        • AndrewBird
          The Mad Scientist
          • 11898
          Why not check the sender first using the information jlevie posted. No point in replacing a part that isn't bad.
          • inwoo
            • Aug 2007
            • 74
            i'm going to check the sender today,
            i don't understand how the sender could be "bad" or stuck.. if the low fuel light works ...
            i'll find out for sure today, and report back.
            • inwoo
              • Aug 2007
              • 74
              i just checked,
              pulled the sending unit out.
              when the float is at the top, it reads about 3ohms
              when the float is at the bottom, it reads 10ohms...
              However, the low fuel light registers, just like it behaves on the cluster.
              I ordered a new sending unit, and will report back in the forum.
              • trry96
                • Sep 2007
                • 28
                Try firmly tapping the guage cluster right where the fuel guage is. I have this problem, and its caused by a wire in the back of the cluster shorting in and out. I'm too lazy to fix it.
                • inwoo
                  • Aug 2007
                  • 74
                  yeah it's definitely not the gauge. when resistance is applied over the cable, the gauge functions over the range in 74-0 ohms
