Heater no longer works, 1, 2, 3, 4 dead.
  • E30Classic
    • Aug 2007
    • 52
    Used to work on 4 only... now blower motor won't turn on at all... Before I go and hunt down the problem by taking the entire dash apart to find out what it is, perhaps someone has a simple fix? Common problem?
    The non-operation, when it would happen before, would coincide with a rainy or cold day, now this weekend it stopped altogether. Ideas?
  • gazellebeigem3
    • Jun 2005
    • 3712
    resistor and/or blower motor. I would start with the resistor, though ideally both should be replaced.
    • Mpowered02
      • Sep 2005
      • 5
      From you description, I definitely would look at the blower resistor. I's a pretty simple fix to replace it. It's located behind the panel at the center of the firewall (above and behind the intake manifold). It's a little block that has a couple different windings of coiled wiring on it. That resistor controls the voltace going to the blower at diferent fan speed switch settings by changing the resistance in the circuit and commonly go bad. Replace that sucker and you should be good. If for some reason it still doesn't work, i'd test for voltage at the blower motor connector. If there's voltage at the blower motor connector when the blower is supposed to be on then it's the blower motor itself. Anyway, hope this helps...
      Alvin Caragay
      '96 AC Schnitzer S3 Sport CLS Replica
      '09 BMW 328i (on lease for the wifey)
      • emi325i
        • Oct 2006
        • 356
        Blow the carbon dust off the blower motor. take 30 minutes to do that.. cheap insurance.. that motor pulls close to 30A on highest setting and that can melt the fuse box... the carbon causes additional current draw.
        I assume you used it on 4 for some time now, so, check the fuse box. mine melted away.
        • E30Classic
          • Aug 2007
          • 52
          Thanks! Fuses are all new, no damage there, but that was a good thing to note for other users that will be searching through this site when this common problem happens.
          I just replaced the resistor and all is well now. :)
          • Court M3
            • Jan 2004
            • 6713
            pics of resistor location? My car has the same problem.
            Continuous For Sale Thread
            323i s50
            • emi325i
              • Oct 2006
              • 356
              it's under the blower motor. you have to have the cover off the blower and it's right there. can't miss it.
              • transatlantic0207
                • Sep 2007
                • 1624
                just a side note if your blower stops working or works on setting four only......DON'T REMOVE THE DASH!!! It's completely unecassary....the blower and resistor are in a plastic casing behind the firewall UNDER THE HOOD right in the middle under the windshield. just get a screwdriver and unscrew the screws to the firewall...15-20m job
                *Same thing to access the windshield wiper motor
                Just wanted to spare fellow e30heads the time and frustration i suffered
                (OO≡≡[][]≡≡OO) ///Motorsport
                In this world, things aren't black & white. Its Delphin!
                Parts, Buy Them--> http://picasaweb.google.com/transatl...eat=directlink
                Snowboard & video game stuff --> http://r3vlimited.com/board/showthread.php?t=148645
                Originally posted by Steve92E34
                Your car is breathing my air, and so are you.
                AND you are both still slow
                • funcrew
                  • Jun 2007
                  • 1223
                  Ressurecting an old thread: Do you have to pull the blower motor out to R/R the resistors?
                  "If the sky were to fall tomorrow, the tall would die first."
                  -Dr. Paul Forrester
                  Do I LOOK like I need a psychological evaluation???
                  • BrewCity11
                    • Mar 2008
                    • 2335
                    No. You can access the resistor w/o removing the motor.
                    I have new resistors for sale if you need one.
                    turk@gutenparts.com
                    • dr.strangelove
                      • Jan 2005
                      • 847
                      • 87e30
                        • Jul 2008
                        • 5676
                        My fan seems weak? Maybe it's just, but it seemed better before. A fuse blew and I replaced that now it works, but just doesn't seem right.
                        Also at level 4 the brake pedal seems to vibrate a bit.
                        Everything still works... just doesn't seem right. Is this a sign for something going out?
                        I just hate everyone.
                        No need for discretion.
                        • funcrew
                          • Jun 2007
                          • 1223
                          I've replaced the fuse, the relay, and the resistor pack. I can spin the fan freely by hand - no binding, but still zilch response from the fan control knob. Starting to piss me off. I guess the fan control switch @ the dash is next - how hard is that?
                          -Dr. Paul Forrester
                          • SiGmA_X
                            • Mar 2006
                            • 287
                            Are you 4srs? Put it on speed 4, use a test light to see if it has voltage at the fan terminals. Have a buddy turn it from 4-off slowly and watch the light dim. Then remove fan, and apply 12v. Then replace the fan.
                            :wgaf:
                            PNW BMW Crew ///
                            '93 325iS
                            '99 528iT
                            • Stevie30
                              • Apr 2007
                              • 1534
                              Do your power windows work? If not, check the connections on the starter. Windows and fan motor are on a circuit that connects at the starter. If you have to pull the fan switch, there are several threads describing procedure. It's not hard, just a bit tedious. Good luck. http://www.r3vlimited.com/board/show...r+controlsink:
                              1991 325ic and 1991 318is
