Car flooded up to doors, will not start,
  • cnardinola318is
    • May 2007
    • 30
    91 318is flooded monday!
    so my car flooded upt to the middle of the doors
    now it will not start, the ele. works fine
    how long should I wait for it to dry out, 1 day, 1 week?
    thanks
    91 318is New Orleans Lives
    www.nolatonight.com
  • Jordan
    • 12916
    Does it crank over normally?
    Did you make sure all water was evacuated (if present) from the cylinders prior to cranking?
    https://mtechniqueabs.com/
    • whowhatwhere
      • Aug 2007
      • 259
      oh god. dont crank it! take the plugs out THEN crank to make sure it isnt hydro locked.
      Oh jordan, i see u ninja edited.
      • mops
        • Jan 2006
        • 138
        got any pics ?
        realistically half way up the doors shouldn't be a problem.... pull plugs out and crnak then engine to make sure there's no water in the cylinders. while you got plugs out make sure you get spark at the end of plug when cranking...
        i dunno really... never had to deal with majorly floded car.
        What do you mean will not start. does it crank ? does it sound ok when cranking ?
        • strad
          • Jan 2007
          • 241
          That's very close to the dme's level. Are you absolutely sure it didn't get wet?
          The current fleet:
          1992 325ic: 148k-171k miles
          1999 Chevrolet Tahoe LT 4WD, 114k-142k miles
          1984 MasterCraft Stars and Stripes Powerslot (not a car :D) PCM Ford 351W, 904 hours
          • ddavidv
            • 344
            Middle of the doors is a bit vague.
            Take the air filter out and see if it's wet. Those things hold water forever. If it's not, then there shouldn't be any water in the engine as the inlet is high enough to avoid that.
            I'd be looking at electrical. Brain boxes, maybe the fuel pump (though I wouldn't see why...that should be sealed). Tell us more. Does it crank and not fire, not crank, try to start but won't...what, exactly?
            Move out of New Orleans! I can't believe people still live there.
            • delphini
              • Apr 2006
              • 680
              Originally posted by mops
              got any pics ?
              May i also suggest a squirt of WD-40 or liquid wrench in the cylinder also, (before you crank her over.)
              :pimp:
              • ptownTSI
                • Jun 2005
                • 1265
                start checking for the fuel pump working and spark.
