So after my long drawn out troubleshooting with my warm starting issue a while back, I'm slowly noticing little things that are wrong. In the process, I replaced the AFM, computer with MarkD, both reference sensors on bellhousing, all ignition parts and filters, temperature switch, and temperature sensor, Bosch O2 sensor.
Now the question. If I have the wrong temperature sensor, will it edit my idle attributes to the computer? My cold starts are flawless. Warm starts are good and consistent. It idles about 200-300 RPM more than I would like. At times it will settle down to 650-700 rpm like after a cold start but will ADJUST ITSELF to about a thousand, like it wants to idle properly but gets told not to. I bought the temp sensor from O'Reillys warehouse so I didnt get it from a reputable BMW parts supply. Would this make a difference? Or are the sensors all the same? My idle control unit adjuster screw has been tampered with but doesnt really do anything but make the car idle higher when I adjust it up.
Thanks for reading!
Thanks for reading!
