Throttle housing to rear of engine block Hose Replacement
I need to replace myThrottle housing to rear of engine block hose. Does anyone have a simple way to access where it attaches to the block? I can hardly see the clamp, much less work with it. Thanks Marc
hmm...if it is the throttle body coolant hose like the one i had to replace, if you unhook the battery, undo starter cables, take off the intake boot, get rid of a few things there it isn't that bad, only took like 15 minutes once i figured out what i had to take off. just a pain in the ass to get there
