Washer fluid pump sometimes works
  • matt_vo
    • Mar 2007
    • 30
    Hi all,
    Sometime this summer I had to take off the hood of my car for some repairs and since then the washer fluid pump sometimes works. I took off the wiring set and found some damage.
    Can someone come up with a part number for this? I checked on realoem but couldn't find anything. There are a bunch of wiring set diagrams but none that indicated the washer fluid pump wires.
    Thanks,
    Matt
  • xLibelle
    • Aug 2004
    • 2673
    you may want to investigate the switch at the stalk.
    can you reproduce the issue? like if its intermittent? hook up the volt meter and make sure its not the pump getting stuck. on the same note, when its not working, make sure your switch is working by tapping into those wires at the column.
    please note, wire problems will provide broken or working, and changing between under motion. since there is lack of motion on the wires, make sure your bases are covered before you go changing the wrong stuff.
    i hope that all made sense
    • thectrlguy
      • Apr 2007
      • 1042
      I concur with xlibelle.... here's the drawing however..... not much to go wrong between the motor and switch, other than the wiring...
      • teamgtnfx01
        • Nov 2007
        • 37
        i have this problem and it makes me so mad i will connect the pump it will ok for a while then all of a sudden normally on a rainy day the fluid will not stop quirting or the wiper will keep on going off
