Car is hesitating/misfiring...
  • riverdale21
    • Mar 2004
    • 786
    When I first purchased the car there was a strange hesitation whenever I would apply 3/4's or more throttle in any gear under any load. I thought it was due to the catalyst and mufflers being clogged. On went a new header back exhaust. Now that the new exhaust is on you can hear what sounds like the engine misfiring during 3/4 or more throttle application. I thought it was the fuel system somewhere. Checked the fuel pressure regulator, no leaks, fuel pump seems ok too. I removed the spark plugs and found excess gasoline on the spark plugs. I cleaned them off. They are new plugs. What could be causing my missfire?
  • dpg23
    • Apr 2004
    • 24
    Sounds like a bad plug wire.
    EDIT: Do the 4 bangers have plug wires or is it coil-on-plug?
    Dan
    1989 325i 5-speed
    • Gus
      • Jan 2004
      • 285
      try your dizzy cap and rotor (im not sure what system the m42 uses but it should be similar to m20 motronic).....i had a similar prob.....really bad idle hunting, and random hesistations or what felt like misfiring around 2k Rpm under no load...just got a new dizzy cap and rotor yesterday..seems to have fixed the prob
      JUNGL3
      1990 "333i" Sport
      • riverdale21
        • Mar 2004
        • 786
        Dizzy cap?
        • Skafrog
          • 1730
          distributor cap
          Dizzy is weak slang ;)
          NASA MidSouth TT Director / GTS2 #018
          Mods: Coastal PS Fluid, 10w40 Oil
          Future Mods: Bosch Micro-Edge Wiper Blades, Painter's Tape, Spark Plugs, Freezer for Nutty Buddys, Adam Nitti CD's
          • riverdale21
            • Mar 2004
            • 786
            Im used to Honda engines, I didn't even know the M42 used a distributor cap since it's not connected to the camshaft. I thought it was a distributorless ignition system.
            • riverdale21
              • Mar 2004
              • 786
              Since I'm going with a turbo setup, are there any upgrades like the MSD boxes that could work on this engine?
