Posting it here since the m10 section is dead....
I got a spare m10b18 bottom end at a machine shop for cleaning / inspection. I already have a rebuild head from the same engine waiting for the bottom end. I got the word from the shop that the crank and rods are fine, one of the 4 cylinder walls have a little bit of rust and they recommended to go with 20 over pistons as re-honing the block might not get rid of all of it.
This leads me to my question. What options do I have for pistons here ? I would like to use existing crank, rods and head. So something that would work here w/o having to rebuild the already finished head would be great. I wouldn't mind bumping the compression a little but would rather not go down in compression. If I'll have to use 91 octane , that's ok too.
I know MaxSil sells m10 pistons, but do they only sell them in OEM spec or can I order them like bearings with xx over ?
Thanks!
Thanks!
