My e34 runs fine then dies out
  • ColdAccord
    • 5926
    My e34 runs fine for a couple minutes, then starts running like shit and won't move. Thought it may be a clogged cat so I pulled the exhaust off, it's running open header right now. Put a scanner on it; no problems, even though once it starts running like shit it throws a cel. It said it's getting 1.12v at the o2 sensor, but the o2 sensor isn't on there.
    I just dont understand because it runs perfect for the first few minutes. good steady idle, etc. I don't understand what it could be? As soon as it starts warming up it dies out. When I put the scanner on it when it started running like shit after I started it and ran it for a couple minutes it was at 54 degrees celsius (~129F)
    any ideas? coolant temp sensor? sending unit?
    Originally posted by blunt
  • shiboujin
    • Feb 2006
    • 2791
    Ive heard of fuel pump problems in E34s before. Maybe some debris is floating around and gets sucks into the filter? When your car dies/is off it falls back off until it runs for a bit more the next time you start it.
    Fuel pressure gauge FTW!
    • ColdAccord
      • 5926
      I think its gotta be something temp related, I mean the thing always runs fine for the same amount of time until it starts warming up
      • e30s52
        • Oct 2007
        • 5235
        my e34 does the same thing. it runs good for like 10mins then dies or kinda sputters. my e34 is a m50 non vanos. i have no clue but im thinking it could be coolent temp sensor. but i will soon find out just order one
        www.gutenparts.com
        • PeaveyBassist
          • Sep 2004
          • 3511
          If you have access to an ocilloscope, you can probe the crank sensor and see its waveform with the engine running. A lot of times, when the car runs fine when cold, but then will die once warmed up, it will be the crank sensor. Usually after it dies, youll have to wait a while to start it again (10 min or so). Coolant temp sensor should be obvious if you have a scanner though.
          RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
          Welcome e30 (brilliantrot '90 325is) 12/23/06
          DaveCN = Old Man
          My signature picture was taken by ME! Not by anyone else!
          If people keep quoting me in their sig, I'm going to burn this motherfucker down.
          • e30s52
            • Oct 2007
            • 5235
            it only takes like a few seconds to start up not 10mins. i dont have a scan tool so i dont know
            www.gutenparts.com
            • eyagel
              • Jan 2007
              • 756
              might be sending unit, those things are expensive i believe....check fuel pressure , then start from there.
              • eyagel
                • Jan 2007
                • 756
                it doesnt seem like anything temperature related.
                • e30s52
                  • Oct 2007
                  • 5235
                  thanks. i hate expensive things:( then less money gos to the s52 swap :(
                  www.gutenparts.com
                  • ColdAccord
                    • 5926
                    yeah for me it runs fine for like 3-4 minutes, then dies out and throws a cel. but when I put a scanner on it i cant find the problem. the car will start up like 5 minutes later, but quickly die out again
