Door Lock Question
  • grlaneriejr
    • 321
    Door Lock Question
    Hey guys, a dumb question. I can't lock my driver's door by pushing the button down. It will lock w/ the key after it's closed only. Is this designed like this? If not, what is wrong?
    Thanks
  • bimmerphile
    • 3495
    Is your car a 318iS? I've seen this problem in 2 318iS's.
    Unfortunately, I don't have a solution.
    • grlaneriejr
      • 321
      No, it's a 85 318i. Does this sound normal?
      • christophbmw
        • Mar 2004
        • 363
        my 85' 318i deos this also. it has done it ever since i have bought it. i think its normal......but i can lock my passenger door when its opened.
        '91 318is
        • LikeCDoos
          • Jan 2004
          • 2522
          it's normal. I believe it does this so you can't lock your key's in your car. Also i think once it's closed you can't unlock it by hand through the window, therefore acting as some anti theft system.
          • aaron_silva
            • 1785
            Incorrect, the doors can be opened from the inside. How do you get the doors open after you start the car (the car locks itself after start)? Just pull on the handle.
            Aaron
            • LikeCDoos
              • Jan 2004
              • 2522
              my car doesn't lock its self after started...
              • bimmerphile
                • 3495
                Nor have any other E30's I've seen.
                As to my above statement, I misread your post. I thought you said you could unlock it by hand after it was locked. Yes, what you are experiencing is normal. You cannot lock the door by hand while the door is open.
                • aaron_silva
                  • 1785
                  When I turn the key the doors and trunk lock. When I turn the car off, the doors and trunk unlock. It has been that way for me since I have owned the car.
                  • LikeCDoos
                    • Jan 2004
                    • 2522
                    That would be a real nice feature to have. Do you have keyless entry or some aftermarket alarm system on it?
                    • aaron_silva
                      • 1785
                      I have a Clifford G5 with motion sensor but that was installed only 6 months ago.
                      Aaron
                      • Tangent
                        • Mar 2004
                        • 476
                        Not being able to push down lock button with dorr open = normal
                        Turning key in driver's side lock ~1/8 turn to lock = doors locked, lock button can be pulled up to open door.
                        Turning key in driver's side lock ~1/4 turn (as far as it will go) = "double lock" = not being able to pull up on button to unlock door as a security feature = only being able to unlock doors from driver's door lock or trunk lock. Only the driver's door has the "double lock" feature. This feature baffled me at first when I would double lock it (without knowing I was doing that) and then wouldn't be able to unlock it from the passenger side door.
                        • LikeCDoos
                          • Jan 2004
                          • 2522
                          if you do the "double lock" there is a way to open your passenger door. You go to unlock from the passenger side and hold the key there while lifting on the door handle.
                          • grlaneriejr
                            • 321
                            Okay, thanks guys. I was just wondering if this was normal or my door was messed up.
                            • christophbmw
                              • Mar 2004
                              • 363
                              i think the newer E30's do that.
                              '91 318is
