Intake manifold
  • Dozyproductions
    • Jan 2007
    • 4682
    Intake manifold
    Are the studs, that sit the throttle body, attached to the manifold or can they be taken off? Friend and I were replacing a lot of things around the area and he broke a stud off :( Nothing is sticking off. I went to the BMW dealership (which they call me mr. trouble by now) and you can order the studs individually so hopefully they can. Thank you for the feedback.
    adam
  • AndrewBird
    The Mad Scientist
    • 11897
    So the stud broke off flush with the manifold? If so, you are going to have to drill a hole in the center of it and use an easy-out to get it out. If that doesn't work, you'll have to drill it completely out and put in a thread insert.
    • Dozyproductions
      • Jan 2007
      • 4682
      Taking a better look, with the throttle off there is a little sticking out. Can it be done then with vice/wrench?
      • Doughnut
        • Oct 2007
        • 869
        If you can get it on, use a small punch and try to tap it around.
        I think your going to have to go the easy out way though for that stud.
        ///Monstrosity. (OO≡≡[][]≡≡OO)
        Aside from showing yourself to be offensive, lacking experience and ignorant in the ways of business, you're also illiterate and imprudent. Beyond that, your sense of liability is severely impaired.
        • Dozyproductions
          • Jan 2007
          • 4682
          alrighty then. Thanks for the responses. Back to garage i go!
          • matt
            • 3731
            Vice grips.
            • AndrewBird
              The Mad Scientist
              • 11897
              Yes, I would try vice grips first.
              A big problem with easy-outs is they have a tendency to brake off in the bolt. And, since they are hardened steel, you pretty much can't drill them out and are therefore, SOL.
              • Dozyproductions
                • Jan 2007
                • 4682
                Just to update, there was just enough to of it left to use a vice. My idle seems to be stable now and everything is working okay. I will probably try to check for torn hoses or leaks anyways though.
                So thanks guys. The BMW dealership in San Luis Obispo was telling me i need to get a new intake manifold :crazy:
                • buhnahnuh
                  • Nov 2007
                  • 69
                  They want your money:hitler:
                  I was taking the exhaust manifold off an old car and i stripped a bolt, and broke the nut off. I asked them and they said it would need to be machined or a new head bought. I just used a bolt splitter and made a groove big enough to get a grip with the Vicegrips.
                  • Dozyproductions
                    • Jan 2007
                    • 4682
                    That would of been a pain! I don't think these people wanted my money (of course they wouldn't mind) more than none of them, including a couple of the technicians, know a m20 engine anymore.
                    • buhnahnuh
                      • Nov 2007
                      • 69
                      I know, you go down to the dealer and say e30 thirty and it seems like sometimes they have to get a reference from a picture out of a book.
