upgrade motor mounts?
  • george graves
    • 19998
    Is there anything getter than the stock e30 m20 motor mounts?
    Originally posted by Matt-B
  • Jand3rson
    • 37587
    Re: upgrade motor mounts?
    You can get urethane ones.
    • george graves
      • 19998
      Ohh that sounds a bit too harsh....is it?
      • Jand3rson
        • 37587
        There will be a lot more vibration and noise. Honesly, the stock units are more than adequate.
        • Beej '86 325es
          • 2639
          If you think the vibration might bother you with urethane, you can upgrade like I did to the E12 mounts. At least I'm almost positive that's what they were from. They were also used on the 6 series. Made for the big six though I know. Pretty sure E12. They're a little stronger and bolt in with no mods.
          -Brandon
          '86 325es S50
          '12 VW GTI Autobahn DSG
          '03 540i M-Sport (sold)
          '08 Jeep SRT-8 (sold)
          For sale:
          S50 TMS chip for Schricks
          • NickP
            • 257
            e12 mounts do bolt in - the only thing that you have to do is grind off the top locating nipple thingy. The e12 mounts have one, the e30 mounts do not.
            • george graves
              • 19998
              thats what I figgured - hopefully they will work will with my m30 swap - I just ordered new ones.
              George Graves
              • Jand3rson
                • 37587
                George Graves
                If you're using them for an M30, you should the mounts for a 635CSi. I think they work on the E30 frame mounts.
                • Beej '86 325es
                  • 2639
                  I didn't have to grind off the nub thing on my car. They fit into a little hole on the subframe for it.
                  -Brandon
                  '86 325es S50
                  For sale:
                  • AdamF 88iS
                    • 2051
                    E12 mounts are the way to go. The deal with the nipple things is that the e12 has 2 and the e30 only has one so you may need to chop the extra one.
                    Nice upgrade though.
                    Adam Fogg- '88 M3
                    Common sense- It's the new 'gifted'
                    • Sean
                      • 5793
                      Where could I buy some E12 mounts? Just any parts place that accepts BMW PN's?
                      - Sean Hayes
                      • rwh11385
                        lance_entities
                        • 18403
                        bump, more info on e12 mounts?
                        • tranceguy
                          • Aug 2004
                          • 139
                          BMA does. There's even a discount for r3v members.
                          VANOS FOR LIFE MAING
                          • rwh11385
                            lance_entities
                            • 18403
                            Well I didn't know on eurowebparts whether it was $22 each or for both.......but BMA makes it seem like both are for $18 (less discount)
                            http://www.bmaparts.com/epcvsoapimc....entid=bmaparts
                            PN: BM012527
                            • E30/M30
                              • 224
                              Are the e12 one's thicker than the m20 one's ?
                              I can't fit any thicker ones as the inlet manifold might start touching the hood.
                              I was thinking about getting the I.E. urethane(sp?) mount's but was worried about the extra noise/vibration.
