Kosei K1 offset
    Kosei K1 offset
    What offset are you guys with Kosei's running. I'm looking at getting a set that are e30 fitment for my VW but I need to know the offset so I can see if they'd work. Thanks
    if the kosei's are e30 fitment they should be 27mm
      I know you can make most FWD wheels fit on RWD cars, but I don't think it works the other way around.
        A et27 offset should work since it's only a 15x7. Eurospeed, you're right in most cases but those will work just fine in this case. Thanks Bhadole.
          15x8 will also work with an et 22.
          Tire Rack has these in stock, call them and ask for Jim.
          I just put them on my car.
          Tony
            on a vw a2?
            past:
            1989 325is (learner shitbox)
            1986 325e (turbo dorito)
            1991 318ic (5-lug ITB)
            1985 323i baur
            current:
              Thought he was talking about an e30, this is an e30 board not vw.
