Hi
This is happening to a 87 325is.
1) Sometimes it takes a long time to start the car, where it turns over about 6-10 times before it starts, and sometimes it starts up right away.
I just installed new cap, rotor and plugs and its still the same...anything else that can cause this?
2) On friday my speedo went nuts for a bit, the speedo all of a sudden went dead...but the car still drove...but when i rev to about 4000 rpm i felt a studder or something...and after about 5 minutes it went away and all is fine.
Then this morning...the speedo went crazy - was fluctuating quite a bit...by about 2000rpms up and down and after 2 minutes it was fine....so just curious
3) my left turn signal is messed up....sometimes it blinks normal, then it blinks super fast, as though a bulb is dead. the rear bulb is fine. but the front seems to be the issue. I put in a new bulb and it still occurs as such....any ideas?
thanks
franklin
thanks
franklin
