Help Troubleshooting a few things...
  • modifiede30
    • 1208
    1) the fog lights. I installed new lenses, and they won't turn on. They worked fine before I installed the lenses. What fuse are they running off of, or relay?
    2) my a/f ratio gauge doesn't ever show steady state. I understand this is normal during partial throttle, but I thought it was supposed to go into open loop at full throttle, at which point it would stay steady. Its wired correctly - I tested the leads during operating conditions and the signal is present.
    3) my oil temp seems low, although I've not been able to find a reference for what it should be. I've not seen it go above 150F since I installed the new gauge.
    4) the ticking of my valves is annoying me but I've check 2 times and they are correctly set. I'm running a 274 cam and have tried .010 and .012 with the same results. However, it seems to be a bit louder at .010 than .012 which is the reverse of what I would have thought. Any suggestions, the whole valve train was just replaced. I assume that the cam may create some additional noise but I didn't think it would be this loud.
    Driving is the only way to go faster....
