whats involved in getting an o-ringed head
  • natorious
    • 672
    just pricing stuff out to see how much money i can dump into a turbo setup for the m20
    what are the benifits of doing this.. what are the downsides
  • riverdale21
    • Mar 2004
    • 786
    I haven't had the opportunity to check this fact but if the M20 is an open deck block having it o-ringed will actually help stabilize the cylinder sleaves under highboost and help create a better seal between head and block. The downside is the price and downtime of having your block and head machined to accept the rings.
    • iXer
      • 242
      O-ringing the M20 block is a good "insurance" to have.
      Most of the M20 turbo folks in Sweden tend to rely on this when they push 300+ hp with the original engine, often in combination with an original head gasket. The combustion chamber design is prone to detonation more so than in the more modern M50 24 valve engine, it's also very difficult to hear and detect detonation on this engine according to Bäckis (a notorious M20 tuner). O-ringing is not an excuse to skimp on engine management! If you're aiming for 300+ hp you should know better.
      I really can't say that there are any disadvantages, besides cost for machining. Here is Ticcos block with M42B18 pistons (he's on this forum):
      • riverdale21
        • Mar 2004
        • 786
        Thus showing the M20 in fact has a closed deck block. I'm used to messing around with little imports.
        • skat 325is
          • 296
          Heres my o-ringed head, cost me like $75.
          • bender
            • May 2004
            • 171
            what size oring and what type of rubber is that?
            sounds interesting... looks like a good DIY project :shock:
            600hp beast
            • 808BMW
              • 2910
              Directly from Andreas, swedish m20 turbo master:
              Originally posted by Andreas
              Stock head gasket without "oringed" will hold to ~ 300-350hp
              And with "oringed" block it holds to 600 hp.
              Change to ARP bolts, then it holds for more then with stock bolts.
              • riverdale21
                • Mar 2004
                • 786
                You wouldn't want to use rubber in a cylinder head. Most tuners use copper rings.
                • skat 325is
                  • 296
                  I dont think rubber o-rings will do anything but get squashed when u torque down the head to the block or melt away with the head.
                  • bender
                    • May 2004
                    • 171
                    thats what i was thinking
                    unless its some crazy space age junk...
                    so i guess when they say o-ring they head.. they mean copper?
                    sorry if this is a retarded question.
                    600hp beast
                    • 89325iturbo
                      • Mar 2004
                      • 723
                      You don't o-ring with copper, you o-ring with stainless steel wire.
                      • NC325iC
                        • Mar 2004
                        • 6565
                        how do i go about o ringing
                        take it to a shop or what
