325I motor with flywheel, etc... ETA tranny, stater issues
  • Pettas
    • Dec 2004
    • 41
    Been through the headaches of getting the car good to go. Got 1 last issue. It sounds like the starter is spinning in the free air. Motor does not turn over at all, its just the starter making all the noise.
    325i motor
    325i flywheel
    325i starter
    ETA tranny
    Any issues known?
  • Pettas
    • Dec 2004
    • 41
    It is popping out, so the starter is not stuck. Looking underneeth, it seems like it comes out above the flywheel, as in to high.
      That combination should work. Are you sure that the starter is correctly mounted? If it is it might be a problem with the starter.
