allergic reaction
  • viali8
    • Nov 2005
    • 673
    allergic reaction
    Not sure if this has happened to anyone here but my girlfriend just came home from switzerland and i have been driving her around in my new e30 that i bought. I had the heat/blower on and she began to feel lousy after a few minutes. It wasn't so bad as when i turned the blower off but she still felt lousy. Therefore my question would be is there an air cabin filter in these cars ? If so where is it. I figured if there is filter of some time it probably is covered with pollen after all years of use. Any help would be great. thanks.
  • SchnellerVert
    • Sep 2005
    • 3948
    There was a cabin filtration system but to retro fit it would be very tough. Finding parts would be tough. Do you have any mold in the car? Mold makes many people ill. It gets in the carpets and then the hvac circulates it.
    • viali8
      • Nov 2005
      • 673
      I do not see any mold in the car. I guess there is a possibility of there being mold under the carpet. Is there air filter i can replace that might fix the problem? I am not sure how the cabin filtration system works. Would it be in my bentley? thanks for the help.
      • SchnellerVert
        • Sep 2005
        • 3948
        Not in Bentley, It's in real oem in the blown up drawings but thinking most parts are going to be NLA, It was an EU thing. I added a Hepa filter to my STBX's VW Passat some time ago when we owned it. It went under the cowl and worked well.
        • viali8
          • Nov 2005
          • 673
          filter
          I am confused. Does my car have a cabin filtration system or not? thanks
          • SchnellerVert
            • Sep 2005
            • 3948
            US spec? NO EU spec Maybe it was an option on AC equipped cars. I have no clue as to where you live, you list Switzerland and Pa.
            • viali8
              • Nov 2005
              • 673
              sorry about that i am now home in Philadelphia, Pa. And yes my car does have air conditioning. I guess it would be best to check the vin#? thanks again.
              • viali8
                • Nov 2005
                • 673
                Maybe i have some mold in the ducts or something. maybe a freon leak too. not sure i am just writing and thinking now.
                • SchnellerVert
                  • Sep 2005
                  • 3948
                  Not likely gonna have it, but you could do a vin check. Did you look at real oem? It shows the housing and how it slides in.
                  If you wanted to add some simple airfiltration you could do a simple cut a home HVAC filter and install it downstream of the fan.
                  Just remember you will have to change it at least annually. The factory setup is to use on Recirc setting.
                  • viali8
                    • Nov 2005
                    • 673
                    cool thanks for the help
                    • viali8
                      • Nov 2005
                      • 673
                      Is this the filter that you mentioned?
                      http://www.realoem.com/bmw/partgrp.d...09&hg=64&fg=10
                      • SchnellerVert
                        • Sep 2005
                        • 3948
                        yes if you goto the hvac section you will see where it goes.
                        • e30s52
                          • Oct 2007
                          • 5235
                          same thing happen to me. it was mold under the back seat and in the truck on that cardboard that fits over the metal piece behind the rear seat. made me sick when i would drive for about 10mins.
                          www.gutenparts.com
                          • viali8
                            • Nov 2005
                            • 673
                            mold
                            this is good to know. thanks
                            • viali8
                              • Nov 2005
                              • 673
                              I must be a moron because i cant find where this microfilter belongs...
