My dash lights are completely out!
    Other day I was putting gauges where my ashtray used to be, and I accident grounded ashtray light and power went out so no problem, checked fuses found blown fuse, replaced but I get no power to the ashtray lights when I turn my lights on so I left it alone, and end of the day, I go out at night, turn my lights on and completely the dash lights are out, checked fuses with test light and they seem to work fine.
    Somebody said it could be Si battery, but SI battery controls cluster lights not outside lights right? Before I start figuring out something and replacing has anybody experienced this type of problem and what could it be?
    Thanks,
    Amirani
    95' M3.
    90' 325i Turboed.
    87' 325eS Fixed.
    check more blown fuses.
      mine went out for a while and kept blowing fuses. i found out that one of the plugs on the licsense plate lights was grounding.
      FOKAI DA'MA'SHI'I ENSANE GRAPPING INT.
        Mine went out when I installed a shift light and it grounded out. I had to replace the actual light switch. The grounding out apparently blew the switch along with the fuse.
        2001 330i - In the garage.
        1986 335is - 325e with Euro 735 M30B34, Under Construction.
        1989 E30 ///M3 - Sold.
        1975 2002 - Sold.
          That makes sense because I was thinking about it but never tested mine out!
          Thanks, I'll keep you guys updated!
          95' M3.
          90' 325i Turboed.
          87' 325eS Fixed.
