i dont think so..... i always knew that one as the "control arm bushing." Thats the one that you can buy an offset replacement for more caster i think.
you need to press it out of the metal ring... and then press a new one in... to get it back on the control arm you must use lubricant and a heat gun and work it back on to the control arm
