HELP!! Fuel pump fuse
  • SamE30e
    • Sep 2007
    • 4319
    OK!!
    So I got my car insured, I'm driving around and I go around a corner and the car dies.
    I check the fuse under the hood and the fuel pump fuse blew, I changed it and it keeps happening. I limp the car home and now its sitting in my driveway not starting. Where is the most common place for it to short out and where is it routed so I can check it.
    I need help urgently..
    Thanks guy.
    1985 325e 2.8 Turbo VEMS
  • SamE30e
    • Sep 2007
    • 4319
    Another thing, I moved the car up the driveway and slammed on the brakes and it blew the fuse.
    Is it possible its in tank?
    • scabzzzz
      Estado de mierda de encargo
      • 6870
      Something somewhere isnt grounded correctly or bare wires rubbing against metal possibly causing it to blow constantly. Put a slightly higher amp fuse in and see if it stops, otherwise you'll have to just chase it.
      • SamE30e
        • Sep 2007
        • 4319
        It doesn't stop. Ok I don't know if its the fuel pump. It is on when the car is starting, but not when it's running..
        • DaveSmed
          • Apr 2007
          • 1407
          Don't ever actually do this.
          -Dave
          2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
          Need some help figuring out the ETM?
          • SamE30e
            • Sep 2007
            • 4319
            Ok so looks like I gotta pull the fuel pump.
            • SamE30e
              • Sep 2007
              • 4319
              Ok fuel pump is all unhooked, but I can only get it out an inch or two then it gets stuck, is there any trick to getting it out, I don't want to break it.
              • StereoInstaller1
                GAS
                • 22679
                Sam, here is the link to your electrical manual:http://www.wedophones.com/Manuals/BM...g%20Manual.pdf
                Look at page 1360-5 (PDF page 43). You will see that the fuse is after the relay. The relay gets power from the battery junction block. The wire going from the battery junction to the relay is red, then the wire out of the relay, into the fuse (fuse 11, 15A) and back to the pump is green/violet. Start by unplugging the pump and using a fresh fuse, see if it stays good. maybe even try a 5A fuse just for testing. If yes, you likely have a bad pump. If it pops, you have a short in the wire somewhere.
                If it were me at this point, I would grab a chunk of wire long enough to reach the fuel pump and power it totally separate from the cars electrical system...so you can see if the pump works...but I would use a fuse on the wire so you didn't melt the wire.
                Good luck, I hope this helps.
                Luke
                Closing SOON!
                Thanks for 10 years of fun!
                • SamE30e
                  • Sep 2007
                  • 4319
                  The pump works. As long as I don't move the car or if I do don't stomp on the brakes it won't blow. So the pump is not the problem its just the wire somewhere. Now i'm assuming its something in the tank because the car hasn't had more then 10L of fuel in it for 6 months, so I guess the gas never splashed around and shorted it out in the tank. I filled it up today and this started. I think it might be the connection the pump itself inside the tank. If not i'm just going to run new wires to the pump, it's easier then tracing all that shit.
                  Does that make sense? If I stomp on the brakes or go around a corner it blow the fuse.
                  I would test it with the pump unplugged but for some reason this circuit looks like its only on when the car is running (relay I guess). Should I jump the relay and try it? If I jump the relay with the pump unplugged that would mean there would be power to the circuit for it to short out if anything, if I do that do I connect the wires going to 87 and 30?
                  If it's something in the tank, what could it be?
                  And where is the relay? Under the dash by the driver kick panel how will I know which one?
                  Sorry for all the questions but I need this shizzle fixed.
                  Edit: Do I need to jump it, or can I just hold the AFM door open?
                  • StereoInstaller1
                    GAS
                    • 22679
                    Did you look at the manual I posted?
                    Closing SOON!
                    • SamE30e
                      • Sep 2007
                      • 4319
                      Yea, I had it before, I can't read that stuff for shit, i'm down with basic electronics. But I did come up with the AFM idea.
                      • SamE30e
                        • Sep 2007
                        • 4319
                        Fixed, the idiot who replaced the tank, clamped the line between the tank mount and it was shorting out.
                        • StereoInstaller1
                          GAS
                          • 22679
                          Wewt! diagnostics FTW!
                          Closing SOON!
                          • SamE30e
                            • Sep 2007
                            • 4319
                            Yea, I started the car, roll it backwards down the driveway reached back pulled the fuel pump plug and slammed on the brakes before it died. It still blew, so it was a wire and not the pump lol.
                            • scabzzzz
                              • 6870
                              So basically i was right.
