Where to start? First, the fact that i don' have a digital camera is going to make this alot harder, sorry. i have my new uncracked dash in place with most of the wire connections made. a few helpful pictures would help me to complete it. i am looking for a picture of the white multi-plug clip that attaches to the fire wall at the drivers feet, it has different colored plugs going in to it. the second would be in the same area, im a looking for a picture of a three wire bunch. one green w/ grey stripe, and two that are green w/ blue stripe. the green w/ grey wire im not worried about, but the green and blue both a have connector ends, the ends could plug into each other, but would create a loop. (not sure where they plug in/ clip to, i don't have them clipped together) The smaller of the green w/ blue connectors would also fit into one of the ports from the white multi-plug clip i mentioned above. with the connections in the places i thought were correct, the car woundn't start (even tried to pop start it), turn signals don't work, and tach jumps to just over 1000 rpm(even though engine is off) when key is in start position. Options my car (86 325e coupe) has: power windows & mirrors, system check computer, fog lights, & ac. Im not sure if any of that will help or not. i know this won't be the easiest to respond to but, you all have come through before. thanks.
