so a while ago i got new H4's with city lights and i installed them, i did a hack job on the city lights cuz i was in a rush, but it worked....
for a while... about a week or two ago, im sitting in my car in front of my friends house and i see smoke coming out of the vents and the dash seal, smells terrible. nothing from under the hood... it eventually stops, but later that night i find out all my dash and intstrument panel lights are out, and my city lights no longer worked, and my tail lights were out. i figured fuses....
so i go to change them and realize that stupid me had put 30 amp fuses where there should be 7.5 and i probably fried something... so i go to change the fuse to the new, correct ones, and they break as soon as i put them in. fuck...
so today i re-did the citylights they way they should have been done in the first place (btw... i tapped them into the front sidemarkers), and i replace all the fuses. Everything works correctly, except one fuckin thing... as soon as I shut everything off (shut off all lights with headlight switch) and shut off the car, the left city light, left parking light, left front sidemarker, and left tail light all stay on, but not the left rear sidemarker, that works fine. Everything else is good, the dash/instrument lights, and all the lights on the right side of the car. just in case it matters, i also previously did the independent fog light mod before the H4's in case that matters in fixing the problem.
Any help would be greatly appreciated. THANKS!
