won't start
  • viali8
    • Nov 2005
    • 673
    won't start
    This kind of a weird problem. Hopefully some one has had the same experience/problem. I came home from work tonight and stopped to get some milk and eggs. I was in the market no longer then 5 min. and when i came out to start my car it would not start. Before the no start issue it ran perfectly fine no issues/noises/stuttering what so ever.
    Not sure if this helps but a couple times before i remember the car taking a few seconds to start up; meaning the engine would crank a few times and then it would start up. Other then that no problems. Does anyone have any suggestions? Thanks Matt
    forgot to mention it is a 89 325i
  • viali8
    • Nov 2005
    • 673
    any ideas
      The first things I'd suspect would be the fuel/main relay or the fuel pump.
      • viali8
        • Nov 2005
        • 673
        gonna go work on the car today hopefully i can find out what is wrong with it
        • viali8
          • Nov 2005
          • 673
          i purchased a new main relay and fuel pump relay. This is the information i have gathered so far but am not sure what to make of it.
          I tested for voltage at the fuel pump with the new main/fuel pump relays installed and i get no voltage.
          But i do get voltage while removing the fuel pump relay and jumpering sockets #30 and #87.
          What is my next step. not sure what to do now. thanks
          • viali8
            • Nov 2005
            • 673
            bump anyone?
            • eyagel
              • Jan 2007
              • 756
              no idea man sorry, i would get it home then u can spend some time seeing thats the culprit..
              • viali8
                • Nov 2005
                • 673
                thanks anyway
                • e30_lover_CT
                  • 182
                  Check your:
                  -fuel pump (disconnect the hose going into the intake and crank it...make sure it pumps gas)
                  -crank position/reference sensor might be bad (something very similar just happened to me on my 84 325e)
                  Rob - Hartford, CT
                  Current: 1989 325iS coupe - "Brutus"
                  Lachssilber, black leather sports interior, 5 speed, imported to US in 1991.
                  Mods: H&R, Bilstein, Brembo, Treehouse, vintage black basketweaves
                  RIP: 1984 325e coupe - "Helga"
                  • brandondan1
                    • 1091
                    Originally posted by e30_lover_CT
                    Check your:
                    +1
                    Check to see if you're getting spark as well. Try giving gas while cranking?
                    91 318is
                    • viali8
                      • Nov 2005
                      • 673
                      i found the culprit. it was a faulty fuel pump. I must of done the electrical test incorrectly. Just bought a brand new fuel pump today and it fired right up. thanks for all your help.
                      • e30_lover_CT
                        • 182
                        congrats :)
                        Rob - Hartford, CT
