I need help bad.
I was at my friends house in guelph. About 75km away from my house. I had just washed my car earlier that day and it was running perfectly. I went inside my friends house for about an hour or two and came out and my car wouldn't start. It cranks over, but doesn't start, I cranked over for a good 5 minutes until I smelt fuel. I left it over night and came back in the morning and tried again, again, no dice.
I'm assuming its getting fuel because I can smell it.
There is no spark though, I pulled the wire off the coil and checked to see if it would arc on a ground (in this case the intake manifold) and again no dice.
From what I understand the coil is on a constant 12v and the ground is triggered by something. The coil is getting 12v, if I put a test light to the - side of the coil and the + of the battery and crank it over the light doesn't go. It has a brand new MSD Blaster SS II coil I put in 2 days ago with no problem and worked fine up until now.
I'm assuming that whatever triggers the coil is not working properly, all the fuses are fine and none are blown.
I'm waiting for the tow truck to come get it and bring it back to my house, I need my car urgently and if you guys could help out that'd be awesome..
Thanks
Sam
Thanks
Sam
