need new cat what to get
  • DrMcDave
    • 1793
    alright i discovered why my car is so loud-there is a hole in the cat.
    what should i get-straight pipes are out, its too fucking loud right now as is.
    should i get a high flow cat? if so where from?
    just need a little help. its cool for now cause it sounds like a dtm car but i can't stand it for any type of distance, the hole coupled with my triflo is so loud is ridiculous.
  • NC325iC
    • Mar 2004
    • 6565
    bmp has a cat its like 300 bucks donno if thats cheaper or more expensive
    • 65Matt
      • 172
      www.summitracing.com sells universal fit hi-flow cats that I have been considering.
      • DrMcDave
        • 1793
        dual in dual out....i didn't feel like searching the website
        the bmp one is 345-seems expensive how much is the stock one.
        • Jordan
          • 12916
          Alot Dave, Alot.
          https://mtechniqueabs.com/
            • 37833
            Have an exhaust shop fix you up with a cat.
            Grover Beach, California
            BimmerHeads.com
            • decay
              • 5637
              what size inlets/outlets?
              past:
              1989 325is (learner shitbox)
              1986 325e (turbo dorito)
              1991 318ic (5-lug ITB)
              1985 323i baur
              current:
              • DrMcDave
                • 1793
                whatever stock is, i have a bb triflo and stock headers so whatever size that is...i'll call an exhaust shop and see what they can do.
                • Jon '92 325ic
                  • 172
                  DEC is an option
                  I've heard that stock is the best option, but if you don't want to spend the $3.4 Billion for OEM, that DEC is the next best option. Can't verify this from experience though as I'm still running the original stock cat. I'm pretty sure that BMA Autoparts sells the DEC. This place does to, but I've never done business with them:
                  http://www.bimmerparts.net/bmwpart/catalytic.shtml
                  BMA will price match (if they're not already lower).
                  This website seems to recommend the DEC as well:
                  • hotghias
                    • Jan 2004
                    • 148
                    does replacing the cat with an appropriate pipe or pipes significantly increase noise?
                    • george graves
                      • 20003
                      $3.4 Billion
                      Naw it like $800 bucksfrom the dealer if I remember right...
                      If you call up your local exhaust repair shop they will hook you up with a car for far less...I usually try to find one of those place on the bad side of town ...
                      Originally posted by Matt-B
                      • Matto
                        • Jan 2004
                        • 800
                        Yes
                        Probably depends a lot on what type of muffler you have.
                        • E30godz
                          • 1524
                          ill sell you mine! it works great.
                          • LikeCDoos
                            • Jan 2004
                            • 2522
                            anyone ever run catless with a stock muffler?
                            • bmwannabe
                              • 900
                              i would run without a cat, seeing as how heavy those motherfuckers get.
                              free flow+reduced weight+sweet sound = triple mods for the price of one :twisted:
