idle adjustment
  • Schnell 318
    • 567
    idle adjustment
    how do i adjust the idle on my m10?
    right now it idles at about 400 rpm which is way too low.
  • kencopperwheat
    King of Kegstands
    • 14396
    There is a flat-head screw on the side of you idle control valve. I'd suggest cleaning it first and then adjusting it. I have my M10 idling at 1k rpms.
    Originally posted by Gruelius
    • Bill 84 318i
      • 1600
      Yeah, if your ICV is silver, use Ken's method.
      If it's black, you have to take off one of the hoses (I forget which) and adjust the screw inside the ICV.
      • Schnell 318
        • 567
        thanks guys
        • Psychomofo
          • 95
          Is 1k rpms normal for the m10 to idle at, or do you have some mods that would require a higher idle speed?
          • grlaneriejr
            • 321
            1000 rpms is about right. Try to go for between 750 and 1000.
            • rs4pro3
              • 5808
              Lucky Bastard My m10 idles at 1000 on a good day ussualy it's more around 2,000 even with the screw all the way in. I'm sure there is a vacume leak but I haven't bothered checking all the hoses.
              85 325e 2.7 ITB'd stroker
              • Bill 84 318i
                • 1600
                Does it act like it's hitting a rev-limiter when it's revving high at like ~2k?
                • rs4pro3
                  • 5808
                  nope, it idles perfectly smooth. Ussualy it's more aroudn 1200-1500 just all depends. The icv may be bad or who knows. It drives fine so I've never messed with it.
                  • drifty30
                    • May 2004
                    • 135
                    yo! my ICV doesn't even have a screw on it. it kinda looks like it had one on it at one point. but now it looks like its a hole plugged up with blue loctite. Is the screw supposed to be at the end of it where the plug isn't? right next to the inlet hose casting?
